devilsrear
Jul 18, 2011Aspirant
Panasonic TXP50GT30 & Readynas Duo 3D/HD Bluray Streaming
Hi Just bought this model of plasma - had to get a new one (g/f fed up me using a ps3 on the old one) Was hunting high and low on the web to actually determine what works and doesn't work - ended u...
Sep 03, 2015Guru - Experienced User
devilsrear wrote:
9. Ok I have aload of MKV's with DTS I converted with "MKV2VOB" to stream via a ps3 will these still work? NO - The picture shows BUT the sound is not recognised. You will need to reconver the audio into something else
My understanding is that this is a ps3 issue. In particular that it only support dts when the media is on the optical drive of the ps3.
However, I don't own a ps3, and my information here could be dated.
