jwstephens1
Jun 10, 2016Aspirant
Password reset isn't working on Readynas RDNP4000
I have a Readynas as below which won't reset to factory default password. I installed new disks, a set of 4 3tb drives, and did a factor reset. After 12+ hours the rebuild finished according to rai...
- Jun 11, 2016
What password are you trying? The default for OS 6 is "password".
jwstephens1
Also Raidar shows "Offline Setup": for the status.
following occurs after trying to do admin login and failing
If I get to password reset screen,
- StephenBJun 11, 2016Guru - Experienced User
- jwstephens1Jun 19, 2016Aspirant
Original seller of the drive replied with that trivia (password = password). Never dawned on me that someone would change the defaults and not make it more of a visible detail that change was made, but ....
- BrianL2Jun 21, 2016NETGEAR Employee Retired
Hi jwstephens1,
If the unit is still running 4.2.x, the password is netgear1. If it's running OS 6.x.x, the password is password. If it still won't work, try clearing your browser cache/settings or completely reset it.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
