jwstephens1
Jun 10, 2016Aspirant
Password reset isn't working on Readynas RDNP4000
I have a Readynas as below which won't reset to factory default password. I installed new disks, a set of 4 3tb drives, and did a factor reset. After 12+ hours the rebuild finished according to rai...
- Jun 11, 2016
What password are you trying? The default for OS 6 is "password".
jwstephens1
Also Raidar shows "Offline Setup": for the status.
following occurs after trying to do admin login and failing
If I get to password reset screen,
Jun 11, 2016Guru - Experienced User
