jwstephens1
Jun 10, 2016Aspirant
Password reset isn't working on Readynas RDNP4000
I have a Readynas as below which won't reset to factory default password. I installed new disks, a set of 4 3tb drives, and did a factor reset. After 12+ hours the rebuild finished according to rai...
- Jun 11, 2016
What password are you trying? The default for OS 6 is "password".
Jun 11, 2016Guru - Experienced User
jwstephens1
Jun 19, 2016Aspirant
Original seller of the drive replied with that trivia (password = password). Never dawned on me that someone would change the defaults and not make it more of a visible detail that change was made, but ....
- BrianL2Jun 21, 2016NETGEAR Employee Retired
Hi jwstephens1,
If the unit is still running 4.2.x, the password is netgear1. If it's running OS 6.x.x, the password is password. If it still won't work, try clearing your browser cache/settings or completely reset it.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team - JennCJun 25, 2016NETGEAR Employee Retired
Hi jwstephens1,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
