david594
Oct 14, 2010Follower
Patriot Signature 1 GB SODIMM PSD1G33316S in NV+
Patriot Signature 1 GB SODIMM PC-2700 DDR-333 Memory Module -PSD1G33316S
So I picked up one of these the other day and it seems to be working just fine in my NV+. Booted fine and run through the memory test 4 times without issue. Reasonably priced at $40 from amazon.com or newegg.com
Specs:
Model
Brand
Patriot
Series
Signature
Model
PSD1G33316S
Type
200-Pin DDR SO-DIMM
Tech Spec
Capacity
1GB
Speed
DDR 333 (PC 2700)
Cas Latency
2.5
Voltage
2.5V
ECC
No
Buffered/Registered
Unbuffered
Heat Spreader
No
Manufacturer Warranty
Parts
Lifetime limited
Labor
Lifetime limited
Specs:
Model
Brand
Patriot
Series
Signature
Model
PSD1G33316S
Type
200-Pin DDR SO-DIMM
Tech Spec
Capacity
1GB
Speed
DDR 333 (PC 2700)
Cas Latency
2.5
Voltage
2.5V
ECC
No
Buffered/Registered
Unbuffered
Heat Spreader
No
Parts
Lifetime limited
Labor
Lifetime limited
- doublerollApprenticePurchased the same memory from newegg as well. On my second mem test and so far so good. Thx!
- kamlungAspirantjust ordered one for my NV+... will update my success when it arrives...
- wtribaAspirantInstalled this, ran through 2 successful memory tests. NV+ would not boot. Reran another successful memory test and still would not boot. Reinstalled original memory and my NV+ boots fine. I assume this showed that this memory module version is compatible with both the hardware and bootloader driver, but not the linux driver.. I'm Running 4.1.7.
- kamlungAspirantlooks like patriot must have changed something in their memory modules... i have the same issue... the NV+ just hangs on booting now... so no success for me... ill see if i can get it exchanged for another brand...
- ChrisMc73AspirantHumm, now I'm really lost on what memory to try. Does Netgear not offer any memory to purchase?
I have a newer NV+, since my last one was defective and I sent it back in and forgot to take out my 1GB Crucial stick, now I have a new NV+ and 256MB of memory, but want to upgrade back to 1GB.
What is the latest on memory that is working in the NV+ these days?
