miogpsrocks
Jun 04, 2015Tutor
Perfectly good drive being wrongfully accused as dead?
Is it possible to have a perfectly good drive being kicked out of the raid array and being labeled as dead simple because it lagged too much and timeout due to being a green drive and slow performance...
vandermerwe
Jun 04, 2015Master
Users do have problems with "green" drives and although some are on the HCL they are not recommended.
Tested with seatools extended tests? In your other thread you say you used "generic" testing software?
What size is the drive?
How many drives in the array?
Are the drives all the same model?
Is this on a NV, and what firmware?
Have you tried it in a different slot - to do this safely you would need to backup, rearrange your drives and restore from backup. I don't think you can just reorder the drives without creating a problem.
