miogpsrocks
Jun 04, 2015Tutor
Perfectly good drive being wrongfully accused as dead?
Is it possible to have a perfectly good drive being kicked out of the raid array and being labeled as dead simple because it lagged too much and timeout due to being a green drive and slow performance...
Jun 04, 2015Guru - Experienced User
Maybe also run the (destructive) write test - I've found it sometimes finds issues that the non-destructive tests miss.
vandermerwe wrote: miogpsrocks, you have recently said you tried seatools and it was failing drives when connected to USB, is this one of the drives you had tested like this and did you use seatools with a sata connection as advised?
viewtopic.php?f=24&t=81152
