miogpsrocks
Jun 04, 2015Tutor
Perfectly good drive being wrongfully accused as dead?
Is it possible to have a perfectly good drive being kicked out of the raid array and being labeled as dead simple because it lagged too much and timeout due to being a green drive and slow performance...
vandermerwe
Jun 04, 2015Master
Seatools can do a Full Erase, which is essentially a destructive write test.
Your data volume is very full, could have something to do with it.
Is the data backed up? If so you could try to swap out one of the other LP disks with the problematic one.
Try the disk in another system first perhaps.
