miogpsrocks
Jun 04, 2015Tutor
Perfectly good drive being wrongfully accused as dead?
Is it possible to have a perfectly good drive being kicked out of the raid array and being labeled as dead simple because it lagged too much and timeout due to being a green drive and slow performance...
miogpsrocks
Jun 05, 2015Tutor
vandermerwe wrote: The full erase is in the advanced menu.
I wouldn't update drive firmware without a backup, and don't assume the data will be ok. This is explained in the Firmware update notes.
This is basically what I'm looking at. Where is the " advance menu"?
You are saying " SEATOOLS" do you mean Disc Wizzard software?
Thanks
