miogpsrocks
Jun 04, 2015Tutor
Perfectly good drive being wrongfully accused as dead?
Is it possible to have a perfectly good drive being kicked out of the raid array and being labeled as dead simple because it lagged too much and timeout due to being a green drive and slow performance...
Jun 07, 2015Guru - Experienced User
As I already said:
miogpsrocks wrote:
This is basically what I'm looking at. Where is the " advance menu"?
To enable Seatools advanced tests, you need to select basic tests->advanced tests, and then enter f8. Then advanced tests show up on the main menu. However, with my seatools they are not enabled for non-Seagate drives (and therefore might not be enabled with the dock, since that sometimes confuses the detection).
