miogpsrocks
Jun 04, 2015Tutor
Perfectly good drive being wrongfully accused as dead?
Is it possible to have a perfectly good drive being kicked out of the raid array and being labeled as dead simple because it lagged too much and timeout due to being a green drive and slow performance...
vandermerwe
Jun 07, 2015Master
vandermerwe wrote: Click on the basic tests menu, is there not an advanced tests option, it should be at the bottom of the list?
Have you actually done this?
You need to click on the basic tests menu, the advanced tests is one of the basic tests options.
If you then want it to appear on the main menu do what StephenB has told you to do with F8.
