module12
Sep 05, 2019Apprentice
Performance drop after 2-3 weeks of uptime
Hi, Every 3 weeks or so performance drops dramatically, to the point opening simple Word/Excel documents from it can take 30-40 seconds. If I reboot it from the web interface, it's fine again. I us...
Sandshark
Jul 04, 2024Sensei
Which NAS model and OS version? It sounds like you are running out of RAM. Are you running any apps that may have a memory leak?
module12
Jul 04, 2024Apprentice
ReadyNAS 204 with latest available firmware. 4-disks in RAID10. No extra apps, and services are at a minimum as well e.g. only SMB and AV. No NFS, no iTunes etc. etc.
- StephenBJul 04, 2024Guru - Experienced User
Does turning off AV make any difference?
Have you ever run a balance and a scrub from the volume settings wheel?
- module12Jul 05, 2024Apprentice
On AV, it's only been enabled for maybe a year - when I first saw this problem 5 years ago it was turned off.
I think I have a scheduled scrub, will check and confirm.
- Sep 02, 2018Retired_Member
