mrg9999-2
Feb 14, 2019Aspirant
PHP malware
My nas seems to be infected with php malware. How can I remove it?
I have flashed the latest firmware but the problem still exists
I have blocked port 25 on my firewall.
Feb 14, 2019Guru - Experienced User
What symptoms are you seeing?
Generally the best approach is to back up the data, do a factory reset, and restore the data from the backup.
