Pezman
Jun 10, 2012Aspirant
Pioneer Pro - CPU Fan Replacement (case:18753339)
Hello, I have a Readynas Pioneer Pro Business Edition. I've owned it for 3 years, and just discovered that it is from "Batch 1" which means my CPU fan has been running at 4,400 RPM for the last thre...
ReadySECURE
Jun 11, 2012Apprentice
I would highly suggest creating a support case like mdgm says. Even if it is out of warranty some help may be available for you if you create an online case. Please update the subject line with your case number once you have one open so we can look into it for you. http://www.readynas.com/support
