Pezman
Jun 10, 2012Aspirant
Pioneer Pro - CPU Fan Replacement (case:18753339)
Hello, I have a Readynas Pioneer Pro Business Edition. I've owned it for 3 years, and just discovered that it is from "Batch 1" which means my CPU fan has been running at 4,400 RPM for the last thre...
mdgm-ntgr
Jul 14, 2012NETGEAR Employee Retired
Please power down the NAS and try the update with the spare disk trick I mentioned above. Sounds like your replacement unit has very old firmware in the flash and thus can't mount your array.
