Pezman
Jun 10, 2012Aspirant
Pioneer Pro - CPU Fan Replacement (case:18753339)
Hello, I have a Readynas Pioneer Pro Business Edition. I've owned it for 3 years, and just discovered that it is from "Batch 1" which means my CPU fan has been running at 4,400 RPM for the last thre...
Pezman
Jul 14, 2012Aspirant
Thanks for your help MDGM!
I have pulled all 6 drives out. I found an old 1TB WD drive. I put it into my PC hotswap cradle and erased the contents and formatted it to NTFS (namely because I didn't know what to do since it didn't like it having some old data on it). I then put it into the 1 bay. Upon booting it up I get ERR: Could not mount root raid d.
Should I be doing something different? Having reread the FAQ I'm going to attempt to do a Factory Reset with the single 1TB formatted drive in it. (http://www.readynas.com/kb/faq/boot/how ... _boot_menu). Let me know if I'm doing this all wrong.
Thanks
Thanks
