Campus
Jun 03, 2015Luminary
Planned ReadyNAS 516 with Crucial MX200 1TB disks
Hi, I am currently planning to move an existing physical server into a VirtualBox instance on a ReadyNAS 516. To achieve max performance within the VM I would like to install several Crucial MX200 ...
mdgm-ntgr
Jun 03, 2015NETGEAR Employee Retired
Do you have the 516 already? If so, can you send me your logs (see the Sending Logs link in my sig)?
For performance SSDs make a lot of sense. If you don't already have the ReadyNAS you may wish to consider the 716X too as that has 10GBase-T ports.
Note that you should use disks from the compatibility list.
If you have issues using Virtualbox you can seek help here but support will be unable to help.
