sparkylx
May 06, 2017Aspirant
Plex and my readynas 102 and access
Hi Ive had my ready nas for a while but im not a silled user. recently when logging in to the drive it tells me it cant check for updates also when i click on plex it cant see my media server. my...
- May 08, 2017
JennC wrote:
In the admin page, go to Network then click the gear icon of the active ETH then click Settings. Under IPv4, you will see DNS servers, add 8.8.8.8.
You can also enter the DNS servers that you see on your PCs (for instance: open CMD in a windows system and then type ipconfig /all )
May 08, 2017Guru - Experienced User
Do you have a static IP address configured on the NAS?
If so, you likely forgot to configure the DNS servers.
sparkylx
May 08, 2017Aspirant
Hi
Thanks for your reply. if you mean on the network settings of my hub, yes ive set the nas drive to be static ip. How would I configure the settings?
