sparkylx's avatar
sparkylx
Plex and my readynas 102 and access
Hi   Ive had my ready nas for a while but im not a silled user. recently when logging in to the drive it tells me it cant check for updates also when i click on plex it cant see my media server. my...
  • StephenB's avatar
    May 08, 2017
    JennC wrote:
    In the admin page, go to  Network then click the gear icon of the active ETH then click Settings. Under IPv4, you will see DNS servers, add 8.8.8.8.
    You can also enter the DNS servers that you see on your PCs (for instance: open CMD in a windows system and then type ipconfig /all
ProSupport for Business
