ariharry
Feb 24, 2013Aspirant
Poor ReadyNAS Support #20277392
Over 3 months ago I discovered i_blocks errors after a scan on reboot of my NV+ V2. i_block errors that were corrected resulted in my loosing files and folders, and it's possible to induce errors t...
mdgm-ntgr
Feb 25, 2013NETGEAR Employee Retired
Did they ever try wiping your volume and creating a new one using EXT3? If not, it might be worth seeing if they can try that.
