Sparked
Jul 22, 2011Aspirant
Possible on ReadyNAS Duo
Is there a way to use the power on/off schedule but also have the ability to turn it on and off manually? You see I have two jobs I'd quite like the ReadyNAS to do. The first is to be the Time Machine...
mdgm-ntgr
Jul 22, 2011NETGEAR Employee Retired
If you turn it off manually it won't power on automatically. There is no way around that.
