ziggie216
Mar 15, 2011Aspirant
Possible to replace the fan for the NV+?
Had the NV+ on for two years straight in my bed room and last night was the first time I had it turned off since one of the HD is failing (HD replacement coming in soon). I almost forgot how quiet my ...
mdgm-ntgr
Mar 15, 2011NETGEAR Employee Retired
Can be replaced, but replacing the stock fan with a 3rd party fan voids the warranty. Using an incompatible fan can damage the hardware. If you still want to change the fan there are some suggestions on the forum. Do a search for "Noctua" and I think you should find some suggestions for the NV+.
