ziggie216
Mar 15, 2011Aspirant
Possible to replace the fan for the NV+?
Had the NV+ on for two years straight in my bed room and last night was the first time I had it turned off since one of the HD is failing (HD replacement coming in soon). I almost forgot how quiet my ...
nicholasr1
Mar 28, 2011Aspirant
Depending on the warranty you can probably get a replacement for the unit. I would call in to NETGEAR to find about your warranty and get a hardware check done.
