JiKon
Dec 15, 2021Aspirant
Power issues RN10400
Hi all. My ReadyNAS device is no longer powering up, well it kinda is and kinda isn't. Please allow me to explain. The power supply green light indicator lights up so I assume the external powe...
- Dec 17, 2021
JiKon wrote:
do you feel like it might be the external power supply that isn't functioning properly
It might be that the external supply simply isn't producing the right voltage (or sufficient power). So you could do a risk-buy of a compatible replacement.
But I think it is more likely are that the issue is due to an internal failure.
Dec 16, 2021Guru - Experienced User
JiKon wrote:
The question I have, if I do upgrade to a newer unit would I be able to transfer the hard drives from the older unit to the newer one without losing any data?
Yes. Though you might have to chance a used unit - it's very hard to find new ones, and the ones out there are often overpriced.
JiKon
Dec 16, 2021Aspirant
Thank you for your reply. Does the said ReadyNAS need to be the same type/model?
Also on a side note, has Netgear discontinued their ReadyNAS lines?
- StephenBDec 16, 2021Guru - Experienced User
It needs to be an OS-6 NAS (RN1xx, RN2xx, RN3xx, RN4xx, RN5xx, RN6xx, RN7xx). It can be either ARM or X86.
It can also be a Ultra or Pro model, though in those cases you need to convert it to run OS-6 before you migrate.
JiKon wrote:Also on a side note, has Netgear discontinued their ReadyNAS lines?
They haven't said, but it is quite possible. Inventory has been scarce for a long time.
