JiKon's avatar
JiKon
Power issues RN10400
Hi all. My ReadyNAS device is no longer powering up, well it kinda is and kinda isn't. Please allow me to explain. The power supply green light indicator lights up so I assume the external powe...
  • StephenB's avatar
    Dec 17, 2021
    JiKon wrote:
     do you feel like it might be the external power supply that isn't functioning properly
    It might be that the external supply simply isn't producing the right voltage (or sufficient power).  So you could do a risk-buy of a compatible replacement.
    But I think it is more likely are that the issue is due to an internal failure.
ProSupport for Business
