FerociousNAS
Jul 02, 2024Tutor
Power On ReadNAS 422 and reboots...
Hello all, Power On my RN422 and after 30 seconds it reboots and then fully boots up. Also have a RN524 doing the same but after two reboot it fully boots up. Other then that they both work fine....
Jul 09, 2024Guru - Experienced User
FerociousNAS wrote:
Thank but the logs show no errors.... 🤔
You should be seeing something in the log zip around the time of the second reboot.
FWIW, I am not seeing this behavior in my own ReadyNAS.
FerociousNAS
Jul 09, 2024Tutor
ok I got the zip log file this time.... Looked at the dmes.log. Not really sure what I'm looking for? 🤔
- StephenBJul 09, 2024Guru - Experienced User
How are you shutting down the NAS?
The errors in dmesg indicate that the volume is resyncing and also that the usb drive was not properly unmounted. So I am wondering if you doing a clean shutdown when you power down the NAS.
- FerociousNASJul 13, 2024Tutor
Issue seems to be resolved. I replaced the dead CMOS CR2032 battery and let the HDD sync up. Unplugged the power and flushed the flee power by holding down the power button for 10 sec, plugged power brick pack in and started up w/o the multiple reboots. I will leave it unplugged for a few hrs and report back.
Thanks for the help! 🙂
