eyewanders
Sep 12, 2016Aspirant
ReadNAS NV+ v3 will not power
Please help. Two nights ago our ReadyNAS was powered down normally to move to a different location. Nothing out of the oridinary happened. There is no hot or burned smell from the unit, but now it is compeltely unresponsive when attempting to power on. A second power cable was tried in a known-good second outlet as well, still no fan spin-up, no lights, nothing. I suppose it could be time to upgrade the unit which I'd actually been research (of course), but there is a significant amount of new data needed since the last full back up.
ser#23J3027A00890
It is v3 (not v2) - MODEL 4210-100NAS
Well I suppose this can be marked as solved before it was ever replied. I contacted a friend/coworker who had an older gen-1 NV+ lying around not being used. I picked it up and swapped its PSU into my unit and I'm back up and running (and prepping for a giant data offload since I don't trust this PSU any more than the one that just failed, particularly since it's nearly 2 years older). At any rate, this takes care of my issue obvioulsy for the time being.
- eyewandersAspirant
- mdgm-ntgrNETGEAR Employee Retired
Support do have the ability for this model to sell a replacement PSU whilst stocks last if the old PSU has failed.
However the NV+ v1 hardware revision 3 is quite an old model now. You can get much better performance with any of our current models.
It has indeed failed. Running fine for the time being with the donor PSU. I intend to move to a new NAS this week. May keep this one around for redundancy as long as it keeps chugging along. We'll see. Thanks for the reply. I did check and found replacements (PSU) for around $125 - clearly not a wise investment at this point.
