sykotik
Nov 04, 2015Aspirant
power options , ( sutting down )
hi, new here so please forgive me if this is in the wrong section , but i would to know about using some of the power options , while in the admin page , you have the power tab/section , with in...
mdgm-ntgr
Nov 04, 2015NETGEAR Employee Retired
The ReadyNAS will be off for the hours the power timer scheduled it to be off and be on for the hours you've scheduled the NAS to be on. So if the hours the NAS is scheduled to be on finish at e.g. 8pm the NAS should shutdown at 8pm.
- StephenBNov 04, 2015Guru - Experienced User
My understanding is if a backup is running the power-off is deferred.
If there are other operations that defer the shutdown, it might be good to identify them.
