jimk1963
Nov 17, 2025Virtuoso
Power outage - RN528X does not auto-power on, causing UPS Slave errors
Early southern California winter storm, lost power for a few hours. Have the following setup:
Cyberpower CP1500PFCLCDA 1500VA UPS
RN528X is USB-connected to UPS and configured in RN OS 6.10.9 "Power" Settings
RN528X Wake on LAN is ENABLED
Power outage triggered UPS battery-low condition after 13 minutes, prompting RN528X to shut down:
However, after power was restored, RN528X did not power back on. It remained powered down.
According to Netgear, an OS 6 device with WoL enabled should auto-power on after a shutdown event:
"When wake-on-LAN is enabled, if the unit is disconnected from AC power it will power on when AC power is reconnected."
Wondering why this did not happen...?
Normally, I would say "who cares"... however in my setup I have 3 other ReadyNAS OS6 boxes configured as "Remote UPS" to the RN528X. They are RN424, RN314, and RN212, all running 6.10.9 and all with WoL enabled. When the RN528X doesn't power back on, the other NAS boxes each begin complaining with this frequent message:
Am I doing something wrong by using one NAS as the "Host" for UPS and the others as "Slaves"? I thought this is how it's supposed to be managed using a single UPS.
That is normal (assuming the UPS battery drained).
That is also normal behavior with your RN424, RN314, and RN212. After they properly shut down, you need to manually power them up again.
Can you explain what WoL has to do with this?
WoL allows you to power up the NAS over the network by sending a "magic" packet to the NAS. Is something on your network doing this? Note it doesn't mean that the NAS will power up when it detects ethernet.
No, but it is rather odd that the RN528 powered down, but the other NAS did not. Are all the NAS (and the network equipment between them) all powered by this UPS?
- jimk1963Virtuoso
Thanks StephenB :
Not sure why you say that it's normal for a NAS to remain powered off when power is restored. I quoted Netgear's website directly, repeating it here:
This is why I mentioned WoL. The sentence reads "Enable WoL, your unit will auto-power on after a power outage", doesn't it? I understand the main use for WoL using magic packets - this sentence indicates that WoL has a dual-purpose. Either that, or Netgear's website is incorrect or misleading.
Also, to be clear (which I wasn't), although the RN528X did not power on after power was restored, the RN314 and RN424 did. The RN212 did not power back on. So the result was inconsistent, I guess you could say. I wanted to be clear that WoL was enabled on all of them.
Re: "odd that the RN528 powered down, but the other NAS's did not" - I didn't provide enough info. They all powered down, which they had to because the UPS was completely exhausted after less than 20 minutes. The outage was several hours long. What I was trying to say was, I was half way across the country when this happened. When power was restored and two of the NAS's came back on, they began frequent barking about no connection to the RN528 UPS master. Generated a lot of annoying notifications that wouldn't have happened if the RN528 powered back on as it should have (well, at least if I'm reading the Netgear sentence correctly).
I'm thinking you mean here:
FWIW, that screenshot doesn't match the web ui. Note the OS-6 manual says nothing about AC power in the WoL section (see page 229):
And the KB article is incorrect - the WoL setting doesn't affect the power behavior.
JulienR - This article needs revision.
jimk1963 wrote:
I'm interested in how I could, if desired, have all 4 ReadyNAS boxes power back on after power is restored, using a WoL magic packet. None of my PC's power back on after an outage but I do have a Lenovo T490 laptop that is running only Home Assistant OS, consuming 7W. That laptop is AC powered so in an outage, the laptop will run for 6-7 hours before dying. Wondering if that laptop could be used to deliver WoL magic packets to each of the ReadyNAS units, after some delay to allow for all the switches/controller to re-establish the network.
This could be done - There is at least one python module that could be used.
- https://pypi.org/project/wakeonlan/
It is possible to send the packet as a broadcast packet, in which case a single WoL packet would wake up all WoL devices that receive it.
One caveat - the T490 might need to be connected with ethernet in order for the packets to be forwarded to the NAS. Particularly if you use a broadcast packet.
jimk1963 wrote:
If the NAS is on an UPS and detects that the UPS is on battery power, it will initiate a shut-down. That reduces the load on the UPS battery, which may last until power is restored. In that case, the NAS never sees a power loss and restore, and does not come back on.
Yes. If you only have the NAS and the ethernet switch connected to the UPS, then the load drops substantially when the NAS shut down. The remaining battery power in the UPS can keep the the switch running for long time (and power continues to be delivered to the NAS, though they use almost nothing after the shutdown).
Though this also should apply to the other two NAS (assuming they were also connected to the same UPS, and that the network path was also connected to that UPS).
A safe way to test your new configuration is to temporarily shift all the UPS devices to normal (unprotected) power, and instead put a different load on the UPS. Leave the USB connections in place, and then pull the main power going to the UPS. When the UPS battery drains, the units should all shut down normally. And if that fails for some reason, the NAS will just keep running (since the power was never interrupted).
- jimk1963Virtuoso
Think I may have found the answer to what happened... Sandshark posted this in an old 2021 thread:
There is still a scenario in which this doesn't help, though. If the NAS is on an UPS and detects that the UPS is on battery power, it will initiate a shut-down. That reduces the load on the UPS battery, which may last until power is restored. In that case, the NAS never sees a power loss and restore, and does not come back on.
Two NAS units were powered on at the time of the power outage - presumably both were gracefully shut down by the UPS (RN528 via USB connection to UPS and RN212 via Remote UPS Slave to RN528). Per the above, these two units would not automatically power back on, and in fact, they didn't. The other two units were powered off at the time of the AC power outage (RN424 and RN314), and both of these did turn on automatically when power was restored. This makes sense now.
With this in mind, I reconfigured the UPS as follows:
- All 4 ReadyNAS boxes have UPS settings configured as SNMP UPS
- The UGreen DXP6800 Pro NAS is USB-connected to the UPS and its UPS settings are configured for USB
With this setup, none of the ReadyNAS boxes should power back on after power is restored from an outage. This will prevent the notification chatter I encountered earlier.
I'm interested in how I could, if desired, have all 4 ReadyNAS boxes power back on after power is restored, using a WoL magic packet. None of my PC's power back on after an outage but I do have a Lenovo T490 laptop that is running only Home Assistant OS, consuming 7W. That laptop is AC powered so in an outage, the laptop will run for 6-7 hours before dying. Wondering if that laptop could be used to deliver WoL magic packets to each of the ReadyNAS units, after some delay to allow for all the switches/controller to re-establish the network. No experience trying anything like this, and don't want to use a Raspberry Pi just for this.
