ahoffer
Aug 04, 2011Aspirant
Power Supply replacement compatibility
I do believe the power supply in my Infrant ReadyNAS RNV1-S2-0000 has died. I bought it in October 2006 from Newegg. The power supply died once before and [then] Infrant replaced it. Now it looks like...
mdgm-ntgr
Aug 04, 2011NETGEAR Employee Retired
Yes, that's the right PSU. As you can see here (http://store.netgear.com/store/netgear/en_US/DisplayCategoryProductListPage/parentCategoryID.44396500/categoryID.44397700) the RND4PSU1 is for both the NV and the NV+.
The NV and NV+ are pretty much the same. See http://www.readynas.com/kb/faq/pre-sales/what_is_the_difference_between_the_readynas_nv_and_nv
