ahoffer
Aug 04, 2011Aspirant
Power Supply replacement compatibility
I do believe the power supply in my Infrant ReadyNAS RNV1-S2-0000 has died. I bought it in October 2006 from Newegg. The power supply died once before and [then] Infrant replaced it. Now it looks like...
ahoffer
Aug 09, 2011Aspirant
My new power supply arrived from Amazon. This will be the unit's third power supply. The original power supply failed while the unit was still under warranty. PSU #2 was the replacement from Infrant and is the newer style with the plastic shield. It shows no visible signs of failure; no leaking caps and no smells of burning insulation. It is a pity. I hope PSU #3 outlasts #1 and #2. At $120 a pop, I can't afford to keep doing this.
The good news is that my ReadyNAS is back online and running fine. And I want to compliment whomever designed the chassis. It is fantastic-- I enjoyed taking the thing apart and screwing it back together. I can't say that about anything else I own, even my Ducati.
