ahoffer
Aug 04, 2011Aspirant
Power Supply replacement compatibility
I do believe the power supply in my Infrant ReadyNAS RNV1-S2-0000 has died. I bought it in October 2006 from Newegg. The power supply died once before and [then] Infrant replaced it. Now it looks like...
mdgm-ntgr
Feb 19, 2012NETGEAR Employee Retired
So are the serial numbers of your units in this range: http://www.readynas.com/forum/viewtopic.php?t=10259
If so you might wish to contact NetGear tech support (http://www.readynas.com/support) and see if they'll issue replacements. They have been known to issue replacements in some regions e.g. US.
