ahoffer
Aug 04, 2011Aspirant
Power Supply replacement compatibility
I do believe the power supply in my Infrant ReadyNAS RNV1-S2-0000 has died. I bought it in October 2006 from Newegg. The power supply died once before and [then] Infrant replaced it. Now it looks like...
mdgm-ntgr
Feb 19, 2012NETGEAR Employee Retired
The Infrant ReadyNAS 600 is long out of warranty and is not affected by the Service Action I mentioned in my post just above yours.
So you've had a PSU failure?
For the 600 take a look at http://www.readynas.com/forum/viewtopic.php?f=11&t=18694
