DBeidle
Jan 15, 2017Initiate
Power Supply Replacement
I have a ReadyNAS 1100 Model RNR4450-100NAS that I bought in January 2008. It won't power on so I suspect a bad power supply. I see that Amazon.com has a replacement Seventeam ST-220FUB-05E power...
Jan 25, 2017Guru - Experienced User
VKGH wrote:
The PSU for NV, NV+, NVX, 1100, 1200, 1500 has a special connector pinout. This PSU is available on ebay:
If you want to make the modification yourself (saving some money), the pin out is here: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
DBeidle
Jan 25, 2017Initiate
Thank-you VKGH and StephenB for your replies.
After much introspection and consulting with a hardware guy (I'm mostly a software guy administering his own servers and laptops), I decided to retire the ReadyNAS (it's been unused for quite awhile -- I was looking to repurpose it recently) and save my pennies for an up-to-date replacement. I could've probably done the modifications myself but I have higher priority (and less risky) items on my To-Do list. I've popped the drives to give to my hardware guy who has the equipment to verify that they're still good to use. The remander of the system will head to an electronics recycler.
It was good while it lasted, and thanks again to those that responded,
Dave
