kevinb1's avatar
kevinb1
Power Timer not turning on OS6 FW 6.4.1 - Legacy Ultra 6
I recently acquired an Ultra 6 Plus, which I upgraded to OS 6, FW 6.4.1, for use in backups. The Power Timer function (which I liked better in the old NV+ models, since I could specify minutes) turns...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Jan 22, 2016
    kevinb1 wrote:
    According to the bios_ver.log, I have a 05/26/2010 FLAME6-2 V1.1 product.
    Ah then this is not an issue with OS6 on legacy at all. There is a known power on issue with an old BIOS on an Ultra 6.
    You will need to update the BIOS to the latest: 06/10/2010: http://www.readynas.com/download/addons ... .5-x86.bin
    Easiest way to install would be to:
    1. Power down
    2. Remove your disks (label order)
    3. Put a scratch disk in (must not be from your array)
    4. Do a factory default (wipes all data, settings, everything)
    5. Downgrade to RAIDiator-x86-4.2: https://community.netgear.com/t5/Community-Add-ons/Downgrade-to-RAIDiator-x86-from-ReadyNAS-OS-notsupported/td-p/859412
    6. Install the BIOS update add-on
    7. After you get an alert that the add-on has installed successfully, reboot and check bios_ver.log to make sure the BIOS has updated.
    8. Update the box back to 6.4.1
    9. Power down
    10. Remove your scratch disk
    11. Put your disks back in same order as before
    12. Set the power timer again and see if it works
    Note that it is important not to interrupt the BIOS upgrade whilst it is in progress as it would brick the system.
