markcrobinson
Apr 17, 2018Follower
Presales: Incremental backup several Network drives to NAS at home
I have about 8T of data on several network drives at my business. I want to set up an offsite backup system that does a "SYNC" type backup to a NAS at home. I've tried a few different models -- One d...
Marc_V
Apr 23, 2018NETGEAR Employee Retired
Welcome to the Community!
Getting two ReadyNAS model or a NAS to NAS Backup solution would be the best recommendation for the setup you have mentioned, more preferably a 4 bay or higher model OS 6 Unit (RN400, RN500, RN600) this is to accommodate your current volume size and also allow for future expansion on both sites. Two units would result in a more manageable backup configuration and data management.
With regards to a backup solution, ReadyNAS OS 6 models pack a few of its own.
RSYNC over SSH which is suitable for backing up over the Internet. Allowing a connection to enter on your Firewall/Router (Setting up rules) or setting up a VPN Connection can also help to achieve this.
ReadyCloud is another way of connecting remotely to your Home site, by installing the Desktop app on your Workstation you can sync your Share folders to your ReadyNAS remotely. You can also setup shares which users will be able to access remotely.
This types of backups will do incremental backups too.
Other backup solutions are also supported. Please see ReadyNAS Backup FAQ.
Community members would definitely have suggestions as well.
Hope this helps!
Regards
