readyhome
Oct 01, 2012Aspirant
Pro 2 CPU Temperature
I just bought a Pro 2 this weekend. I have 2 3TB disks in RAID 1 configuration with RAIDiator 4.2.22. The temperatures from the Status|Health tab are: Disk 1 42C/107F Disk 2 39C/102F CPU ...
Lithium-Admin
Oct 10, 2012Novice
readyhome wrote: RMA. Spent some time with support and he was excellent. The upshot is he had a Pro 2 with a CPU temperature of 40C and I am steady between 70-76C. A new Pro 2 will be on the way.
A question: When the new one comes and I install my current disks, will I lose all the data currently on the drives? I suspect the answer is yes, but if anyone has an idea of how to insert them and be up and running, I'd appreciate hearing it.
Thanks to mdgm for his replies and Kostia for his help.
Did you get the new Pro 2? How are the temps?
I just got mine as well and the temps tend to be around 70 C even in idle.
Device Description Status
Disk 1 WDC WD20EFRX 1863 GB , 39 C / 102 F , Write-cache ON OK
Disk 2 WDC WD20EFRX 1863 GB , 36 C / 96 F , Write-cache ON OK
Fan SYS 2509 RPM OK
Temp CPU 69 C / 156 F [Normal 0-80 C / 32-176 F] OK
Temp SYS 33 C / 91 F [Normal 0-65 C / 32-149 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 27 minutes OK
