readyhome
Oct 01, 2012Aspirant
Pro 2 CPU Temperature
I just bought a Pro 2 this weekend. I have 2 3TB disks in RAID 1 configuration with RAIDiator 4.2.22. The temperatures from the Status|Health tab are: Disk 1 42C/107F Disk 2 39C/102F CPU ...
readyhome
Oct 11, 2012Aspirant
honcho wrote:
readyhome wrote: RMA. Spent some time with support and he was excellent. The upshot is he had a Pro 2 with a CPU temperature of 40C and I am steady between 70-76C. A new Pro 2 will be on the way.
A question: When the new one comes and I install my current disks, will I lose all the data currently on the drives? I suspect the answer is yes, but if anyone has an idea of how to insert them and be up and running, I'd appreciate hearing it.
Thanks to mdgm for his replies and Kostia for his help.
Did you get the new Pro 2? How are the temps?
I just got mine as well and the temps tend to be around 70 C even in idle.
Device Description Status
Disk 1 WDC WD20EFRX 1863 GB , 39 C / 102 F , Write-cache ON OK
Disk 2 WDC WD20EFRX 1863 GB , 36 C / 96 F , Write-cache ON OK
Fan SYS 2509 RPM OK
Temp CPU 69 C / 156 F [Normal 0-80 C / 32-176 F] OK
Temp SYS 33 C / 91 F [Normal 0-65 C / 32-149 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 27 minutes OK
I've had the new box for almost a week. The temperature hovers between 50C and 55C. Here's the latest stats:
Disk 1 Seagate ST33000650NS 2794 GB , 41 C / 105 F , Write-cache ON OK
Disk 2 Seagate ST33000650NS 2794 GB , 39 C / 102 F , Write-cache ON OK
Fan SYS 827 RPM OK
Temp CPU 54 C / 129 F [Normal 0-80 C / 32-176 F] OK
Temp SYS 29 C / 84 F [Normal 0-65 C / 32-149 F] OK
UPS 1 APC Back-UPS ES 650, Battery charge: 100%, 25 minutes
I appreciate beisser's point about the spec for the atom (I found an Intel site that said it was rated to 90C) but what happens if the CPU temperature exceeds 80C? Does the firmware start sending warnings? Does it shut down the ReadyNAS? Does it do nothing? I don't know, so I called support, who issued the RMA. My CPU temp got as high as 76C, which was too close to 80C for my liking. (BTW, I recalibrated the fan while writing this post and the CPU temp is now at 50C.)
