readyhome
Oct 01, 2012Aspirant
Pro 2 CPU Temperature
I just bought a Pro 2 this weekend. I have 2 3TB disks in RAID 1 configuration with RAIDiator 4.2.22. The temperatures from the Status|Health tab are: Disk 1 42C/107F Disk 2 39C/102F CPU ...
Lithium-Admin
Oct 12, 2012Novice
Just got my new box
Device Description Status
Disk 1 WDC WD20EFRX 1863 GB , 36 C / 96 F , Write-cache ON OK
Disk 2 WDC WD20EFRX 1863 GB , 35 C / 95 F , Write-cache ON OK
Fan SYS 600 RPM OK
Temp CPU 54 C / 129 F [Normal 0-80 C / 32-176 F] OK
Temp SYS 33 C / 91 F [Normal 0-65 C / 32-149 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 27 minutes OK
better temps... but it could be because it's running firmware .19 instead of the .22
Fan SYS 600 RPM OK
