Equinox1
May 17, 2015Guide
Pro 6 airflow direction
i have quite a curious situation. I own two Pro 6, and the airflow is not the same on both machines. On the newer one, the air gets sucked from the harddisk and from the side and the hot air gets e...
Sandshark
May 20, 2015Sensei
Both my Pro 6 and older Pro BE exhaust to the back. There was corrective action for units with improperly connected fans quite a long time ago. I was not affected and don't recall the specifics. You should do a search.
