JKC1
Feb 07, 2012Aspirant
Pro 6 Long in the tooth vs. Bleeding Edge Gums
Any word on when the Pro 6 will support USB 3.0, Sata 6.0 GB drives, and the new Seagate Barracuda 1TB-per-disk technology (3 TB ST3000DM001)?
PapaBear1
Feb 07, 2012Apprentice
JKC - Actually on home networks with a gigabit network connection (1000 Mb/s) you can't even use the SATAI hard drives to their fullest capability (1500 Mb/s) much less the SATAI+I hard drives (3000 Mb/s). In order to get the full benefit of SATAIII hard drive speed you would need a 10 gigabit network connection. On the new high end computers with the SATAIII connections and the internal controllers to match, then that is great for disk intensive operations, but it is difficult to get that his speed across the network.
