sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
PapaBear1
May 17, 2012Apprentice
Unless you are running some extensive add-ons, it would be a waste of money. For the purpose of simple server functions, such a file storage, the Pro 6 is more than capable of saturating a gigabit ethernet network. In fact, so are the Ultras. Only when running an application on the NAS itself could the additional memory and CPU speed provide some benefit.
In addition, you would void the warranty.
As to the upgraded memory, be sure to run the memory test several time through as even though the machine runs, it could impart errors into the files and that would be a disaster.
