sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
sleepy06405
May 17, 2012Aspirant
I'm not a normal user, I'm an enthusiast. I delight in pushing devices beyond their standard documented specifications. I don't fear data loss, I welcome it.
Memory tests passed, 9 runs, 11 hours using generic PC2-6400 CL6 dimms I had lying around in the area of my basement which is reserved for violating warranties on products I've owned for less than 24 hours. :)
That being said.. Does anyone have information on upgrading the CPU? If not, I'll just try it and post my results. The limitation is going to be what the BIOS supports. It'll probably take an e5800 but it might also take a real core2duo chip too. Someone at netgear knows and can save me trial and error...
