sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
ReadySECURE
May 17, 2012Apprentice
Any CPU and Memory upgrade information available is from intrepid engineers like yourself. All official responses will be along the lines of don't do it, or BEWARE the loss of warranty support from swapping out the internal hardware.
