sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
sleepy06405
May 18, 2012Aspirant
mdgm, Do you know if I'll require a screen for this? For example, will the bios behave like a standard pc and expect me to press something like f1 to acknowledge a hardware change? I read about the vga header and plugging a keyboard into the usb port, that was my next fun project to try after the cpu. It seems like theres serial port connectors in there too. I'm wondering if I could use one of those with a serial terminal to get a console instead of vga, simply because I have plenty of rs232/eia232 stuff here but no vga header connectors.
