sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
mdgm-ntgr
May 18, 2012NETGEAR Employee Retired
Don't think having VGA is necessary but it's nice to have.
Attempting to use the serial console is not supported and you'll get no help with that here.
