sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
sleepy06405
May 21, 2012Aspirant
Well that was boring, it works. No broken screws in the chassis or anything exciting. Not much of a speed difference with this chip. Temp no higher than stock. I'll research what else it'll take and report back if I find anything useful. Not that I recommend this but if you're like me and you can't help it, get a SL9ZF E6700 on ebay, it'll work. The SL9ZF is the specific model of the 6700 that worked for me. But again, don't do this, especially if you've never replaced a cpu before.
VS
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
stepping : 6
cpu MHz : 2659.502
cache size : 4096 KB
VS
processor : 0
cpu family : 6
model : 23
model name : Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
stepping : 10
cpu MHz : 2593.494
cache size : 2048 KB
