sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
sleepy06405
May 22, 2012Aspirant
A qx6700 boots too.
Intel Core2 Extreme CPU QX6700 2.66/8M/1066 SL9UL
I am actually scared running this chip. It makes way too much heat for this heatsink. It runs about 30% hotter than the core2duo but its running the fan at max to accomplish that. However 30% hotter is only 54c and far below the max of 80 something. I'm not going to run it but if you're good with cooling systems, you could make this work.
NAS:~# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 Quad CPU @ 2.66GHz
stepping : 7
cpu MHz : 2394.203
cache size : 4096 KB
