sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
Westyfield2
Jun 04, 2012Tutor
Just been reading through this, I too have the ‘new’ Pro 6 (RNDP6000-200) with the Pentium D E5300 as standard.
I’d want to keep the 65W TDP, but is there anything faster than the Core 2 Duo E6700 that it can take? I know it’ll be faster than stock as it’s a newer architecture and got more cache, but the headline clock speed is the same.
I was going to go looking through the listed compatible processors on ark.intel.com for the Q963 & Q965 chipsets… but then noticed that the standard Pentium D E5300 isn’t listed as compatible. Are we sure Q963/Q965 is the correct chipset?
