sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
Westyfield2
Jun 05, 2012Tutor
sleepy06405 wrote: I noticed that the stock cpu isn't on that list, neither is the q6700 or qx but they all work in there. Eventually the chips will get cheaper on ebay and I'll waste some money on more experiments :)
Ones I'd fancy trying are E6700 and E7600 on 1066MHz FSB. Then on 1333MHz FSB (will it even do 1333MHz?!) it'd be E8600, Q9505S, and Q9550S. Those two Quads are rather expensive though!
(For any naysayers, all of the above are 65W TDP just like the stock CPU :)).
